Dish's Answer to My Problem | SatelliteGuys.US
jgags6
1,107
68
Rockford,IL
Like many of you with 622s, 211s, or 411s are having, im having audio sync problems on the OTA on both my 411 and 622. So about a week ago i called Dish, they told me they know nothing about this and to call back in a week to see if their techs know an answer to this problem. So 9 days later i called back. The AMERICAN csr told me that since when i had the 2 recievers installed the OTA wasnt out of sync that it must be my antenna. So she advised me to get a new antenna and if the problem still isnt solved then i should call back and they will have a tech come out and investigate. What should i do?
Keep letting them know your problem is their problem. It is on their end, not an antenna. Software issue.
Just be firm with them, lie about your signal strength on OTA (or tell them the truth about your signal if it's strong / above 75) most CSRs (india or america) don't know about this issue like we do, and there's not much they can do if they did know about it. For the time being, follow the advice given here and wait for the next software update (hopefully next friday or the friday i'm guessing this after looking at their 622 release history/rate)
Uplink activity for the week of Monday april 3rd 06
Limit on # of receivers one can have active?
