I tried to display pictures with the AZ and it won't go. If you keep trying it freezes up. They are regular JPG images about 4~5 mb. Pictures are loaded in the pictures folder on the internal HDD. Anyone use this feature? Found any dos and don'ts?
Magic,
I have viewed photos of roughly the same size from my cellular phone camera. I tried several methods to view the pictures via the AZBox and they all worked just fine. Here are the methods that I utilized:
1] I removed the micro SD chip from my cell phone and put it in a USB adapter and plugged that into my PC. Then I opened MazEdit and FTP'd several photo files from the chip to the AZBox's /DATA/hdb1/picture folder using the click, drag and drop method. Then I opened the PHOTO browser from the HOME menu options where you can select: TV mode (1) - YouTube (2) - PlugIns (3) - Movie (4) - Music (5) - Photo (6) - File Mgr (7) - FTP (8) - RSS News (9) - Browser (10) - Settings (11). Then I selected the PHOTO subfolder and the images I transferred via FTP were present and viewable.
2] I inserted the USB adapter with the memory chip from my phone into the USB port of my AZBox and selected the PHOTO browser once again and this time selected the subfolder USB1. The entire content of the memory chip was presented and I was able to select individual pix or run slide shows of selected (checked off) photos or select ALL the photos for a slideshow.
3] With the memory chip attached to my USB port of the AZBox, I selected FILE MANAGER ? USB1 ? sda1. Checkmarked the box in front of sda1 and press OK, highlighted My_Images and pressed OK. In a few seconds, the entire list of photos was displayed. I check-marked several randomly selected picture files. Clicked on the DETAIL MENU and selected the option to COPY. Then exited so that I could get back to FILE MANAGER ? PHOTO, highlighted the first file in the PHOTO pictures list and selected the DETAIL MENU and found the PASTE option, highlighted it and pressed OK. The selected images were then copied from the USB adapter/memory chip and pasted to my HDD. Now, I could remove the USB adapter and memory chip from the AZBox and the pictures that I copied and pasted were viewable from the main PHOTO album option (option #6 from the HOME menu).
Everything seems to work really well. The files all show up as just a "file name" at first, but there is an option to create thumbnails. It states that creating thumbnails takes several minutes, but for just a few files, it only required a matter of seconds.
Only suggestion I have is to check the JPEG (*.jpg) format to be sure that it is correct and not some similar looking format extension like *.pnj etc.
RADAR
Well I've figured it out. I can display all kinds of pictures even pics stored on the network. Just can't display pics over 4mb. Always get "Image Draw Error" So the pics that would look pretty good on a big 52" TV won't work...about right LOL
Most all of the pics I have posted here were taken with my Samsung HZ50W 14mp camera which produces pics just under 4.5MBView attachment 74399
Limited time offer
