Because of LOS issues I can't get better than 40% on 101 wit my dtv dish. I'd lke to use my FTA dish to watch 101 since that dish has no LOS issues with that sat. However the dtv receiver can't address a disque port..any way around this?
If you can't get adequate signal strength how can you say this is the only place you can get all three?LordAlex said:if i have it moved then i'll loose 119. the spot it is in now is the only place all 3 can be seen. i have alot of trees.
boba said:If you can't get adequate signal strength how can you say this is the only place you can get all three?![]()
Iceberg said:a diseqc switch doesnt work with DirecTV. You need a 22k switch
Iceberg said:yes. I used a 22k switch with a Invacom quad with no issues
Limited time offer
