TurboMazda
I didn't have to do anything in the settings, now I read info about this switch and found the word Bi-directional now can someone explain me what it really does?
Variants DiSEqC
-DiSEqC 1.0 - it allows to be switched between 4 companions;
-DiSEqC 1.1 - allows to switch more than 4 companions;
-DiSEqC 1.2 - allows to make the control for position..;
-DiSEqC 2.0 - the bilaterial mode of data exchange in DiSEqC 1.0 is added.
Levels DiSEqC 1. ? assume unidirectional communication - only transfer of commands from a receiver to remote terminal units. Levels DiSEqC 2. ? provide transfer, both commands from a receiver to remote terminal units, and answers of these devices to a receiver. Besides, depending on a set of formed executed commands and, accordingly, a set of supported devices these levels share on three subtotals: DiSEqC ?.0, DiSEqC ?.1 and DiSEqC ?.2. Here often there is a mess. For example, it is possible to assume, that level DiSEqC 2.0 above level DiSEqC 1.1, and a receiver supporting DiSEqC 2.0, should work, for example, with switch DiSEqC 1.1. Actually, DiSEqC 2.0 is «the two-forked version» level DiSEqC 1.0, and includes only a set of commands of level 1.0.
LNB will work and with DISEqC 4x1-1.0 or DiSEqC 4x1 - 2.0
Hello. It is necessary it will be defined, how many you think to establish Dish and LNB.
If 4 LNB will go 1 DISEqC 4x1-1.0 or DiSEqC 4x1 - 2.0 report
If 6, 8, 10 LNB will go DISEgC 6x1-1.1 and DISEgC 8x1-1.1 and DISEgC 10x1-1.1
If it is more 8-16 LNB that below a photo and how to include. If the receiver supports report 1.1
At me on 4 Dish it is included 16 LNB.? by the cascade has connected 1 DISEqC 4x1-1.1 plus 4 DISEqC 4x1-1.0. Perfectly all works.
If at you is in a receiver 12V.?? it is possible to connect 8 LNB through the relay 12V.
There are at us on sale and switchboards DISEgC 16x1-1.1 and DISEgC 32x1-1.1- But they are expensive ---------------------------------------------------
It is possible and 40 LNB the cascade to connect-report 1.1.??? switchboard DISEgC 10x1-1.1 plus of 10 pieces DISEqC 4x1-1.0 or DiSEqC 4x1 - 2.0
-+ 64 LNB
