OTHER - DMSI VBox7 shift problem | SatelliteGuys.US
OTHER DMSI VBox7 shift problem
Magic Static
7,498
4,853
Montana
It has come to my attention that there is likely a issue with a production run of VBox7s. I had a late model DMSI VBox7 NIB on the shelf and decided to do a project with it. I began to notice many differences between this unit and it's predecessor VBox7. I discovered that the "Shift" feature did not work also. I checked with other VBox owners and indeed the shift function was found to be not working in the other units of the same build. Now there is a mistake in the owner's manual sent with these units. It gives the wrong procedure for the shift operation. The very same mistake is written into the VBox II manuals also. :( But no matter how you try the unit doesn't respond to the shift button.
I am wondering if other people have come across this issue. These late model VBoxes have a different firmware in them. One way to tell is when the unit is "off" the decimal point that stays lit on the display will be the 3rd digit. The earlier ones will have the second digit lit.
Another difference is the motor/ sensor connectors. The late model will have all the connections in a row. The early one has them arranged in a square pattern.
Does your late model VBox 7 have a working shift function?
Reactions: KE4EST and Titanium
OTHER recommendations ?
OTHER Sathawk or saudon sat S2 receiver
