My basement is currently under construction, but I would like to start planning my home theater setup. I want to run two RG6 cable into the basement, to hook-up a HD DVR but I'm out of ports on my sat. My current Slim-line 5LNB sat only has 4 RG5 ports which are all being used. Should I call D* and order an 8 port mutiswitch, or is there another way around this? If I order a switch, can it be installed in my garage? This would make my life easier if additional runs are needed. Thanks in advised for your help.
