do I need a super dish to get international channel? | SatelliteGuys.US
It depends which channels you are looking for.
Some are on 61.5 or 148. More are on 121 (superdish).
You can check here for the full list and see which channels you want.
http://ekb.dbstalk.com/dishlist.htm
You might want to consider the superdish since most or all channels are on it as well as being "future-pruffed".
Most of the internationals are available on the wing satellites. There are only a handfull, about a half dozen last time I checked that were SuperDish only. However, many of the internationals on the wing satellites are on 121. There are currently no internationals on 105.
811- frame rate problem; video output stuck in "slow motion"
uhf mod
