D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Jun 5, 2012 #1 Remote seems to be dead, not even a battery issue.
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,501 29,478 Rohnert Park, CA Jun 5, 2012 #2 PM one of the DIRT members and they will send you a new one.
D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Jun 6, 2012 #3 In another instance the customers dog got ahold of a 20.1 IR, Are those $19.99 to replace?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Jun 6, 2012 #4 DishInstallAdam said: In another instance the customers dog got ahold of a 20.1 IR, Are those $19.99 to replace? Click to expand... Put your customer in touch with DIRT they may get a freebie.
MattG@DISH SatelliteGuys Pro Dec 30, 2010 3,871 243 Denver, Colorado Jun 6, 2012 #5 DishInstallAdam said: In another instance the customers dog got ahold of a 20.1 IR, Are those $19.99 to replace? Click to expand... The dog getting the remote is considered customer damage, so there is a charge to replace it ($20 most likely). My dog had gotten a hold of my remote awhile back too. Luckily I don't use my TV2 remote for my 922, so I programmed that one at TV1 instead
Dishman1978 SatelliteGuys Pro Jul 31, 2010 3,274 90 California Jun 7, 2012 #6 DishInstallAdam said: In another instance the customers dog got ahold of a 20.1 IR, Are those $19.99 to replace? Click to expand... "I don't get it, the batteries just wont hold a charge. Wait where did these holes come from?"
