Does anyone get ONN on SBS6 & AMC6? | SatelliteGuys.US
satcustomer
304
California
I get it with good quality on SBS6, as I should, but also get it, with a lot of pixelization on AMC6? GBN, the one FTA channel on AMC6, has good signal quality of 60% or so and comes in pretty good, so I know AMC6 is AMC6. I'm using USALS on my motorized system.
Sounds like you may need to tweak your setup as ONN is not on AMC 6. Also, GBN is a VERY strong signal, you should probably get higher than 60 so that is why I say this.
I damn near blow the meter on all my boxes with that GBN.....Coolsat shows 85 (max) and Pansat shows 99
Could it depend on my location that I'm getting the signal quality I'm getting? But isn't what I'm getting good? My zip is 94583. I'm using a Fortec Star Mercury II receiver.
since you're on the west coast, the signal has farther to travel. I'm in MN where IA6 is my TS so AMC6 is only 20 degrees away.
So that probably is it :)
Aiming Between Satellites
My Install.....
