Does Anyone have d11-100 | SatelliteGuys.US
If you go into Menu->Settings->Setup->Info & Test->Right under "Original Version" you'll see the "Previous Upgrade" where your software version is. And the D11-100 is the ugliest of the D11's.
"If you go into Menu->Settings->Setup->Info & Test->Right under "Original Version" you'll see the "Previous Upgrade" where your software version is. And the D11-100 is the ugliest of the D11's."
I think it is the best looking! I just had one deactivated and replaced with an R15. I think the D11-100 looks much better than the D11-500.
Denver Apt intall
Well I Got My DVR R15 replacement.
