does anyone use a thomson saginaw actuator? | SatelliteGuys.US
drhydro
1,572
Howdy folks,
I have a thomson saginaw actuator that i have some questions about. I was under the impression that it uses a hall effect sensor, but in talking with the folks at skyvision they informed me it was a reed switch. How can i tell the difference?
Thanks in advance :-D
drhydro said:
Howdy folks,
I have a thomson saginaw actuator that i have some questions about. I was under the impression that it uses a hall effect sensor, but in talking with the folks at skyvision they informed me it was a reed switch. Thanks in advance :-D
They make both types.
You have to open up the motor housing and take a look. If you don't see a Reed sensor or switch, it uses a Hall sensor.
Actuator Wiring
Replacement Reed Switch for Saginaw
Pictures of Reed Sensors
How It Works: Motor On A Hall Effect Switch
How It Works: Reed Switch Motor With A Transistor
Well i found out the actuator i have does have a reed switch, thanks for the input :-D
