does Dish DVR has build-in QAM tuner? | SatelliteGuys.US
testarc
31
I guess the answer is NO, but just want to make sure. Dish doesn't have my local channels in HD and I don't like an external antenna. Since Tivo doesn't support Dish, seems we only option will be to have two DVRs?
The 811 would only decode QAM on the satellite tuner. It was used for single wire distribution in multi-dwelling units. It would not decode clear QAM on its antenna input.
Packages
If I cancelled...
