Does DPH42 require power inserter? | SatelliteGuys.US
Ward J
2
Simpsonville, SC
I recently obtained a Hopper 3 to replace a well used Hopper 2. The installer used a DPH hybrid LNBF that receives only 61.5 and 72.7. I would like to also receive the 77 sat. He advised that I must use the DPH LNBF's and they do not make one that receives the 77 sat. However it looks like if I use the DPH42 switch, I can use my old 1000.2 eastern arc LNBF that receives all three of these sats. All the DPH42 installation diagrams show the use of a power inserter. Found the DPH42 on SolidSignal.com, but when I called they advised that it does not come with a power inserter and that the DPH42 is directly powered by the Hopper 3. I then checked with DishDepot and they advised that their DPH42 does need the power inserter and theirs comes with it. Which is correct????? is a power inserter required to use the DPH42?
DishDepot is correct.
Tis true
Doesn't the EA DPH LNBf have a wing satellite input? Use a Dish 300 with a DP Single LNBf and Ward should be good, right?
Edit: Yeah, like this:
Reactions: JSheridan
Just out of curiosity, what programming it is on the 77? I see some of you guys are using a 77 or want to be able to use the 77 and I'm not sure what's on there that you can't get on the 61 or 72? Other than Latino programming
Current DTV subscriber debating about Dish
Installation of Hopper 3 / Joey 2.0 next month
