Does external drive require external power? This used to be a requirement, but external powered drives are harder to find.
The one I have for my Tablo does.Does external drive require external power? This used to be a requirement, but external powered drives are harder to find.
Looking at the DISH website, they are not listing powered as a requirement any longer.Does external drive require external power? This used to be a requirement, but external powered drives are harder to find.
I've been using WD for years and years.What is a good external powered Hard Drive to purchase?
Same here. I am still using two WD 500GBs that Dish recommended years ago.I've been using WD for years and years.
I am using a powered Elements. It is a 1TB and not available any longer but 2 TBs are.Which model of WD? I use WD My Book now, but do not see them available anymore in 1 TB size. The 2TB is twice the price of the passport or element.
I am using two powered Western Digital My Book WDH1Q10000 500GB.They are around fifteen years old.Which model of WD? I use WD My Book now, but do not see them available anymore in 1 TB size. The 2TB is twice the price of the passport or element.
That depends on what kind of USB drive you buy, spinning disk or SSD. SSD uses much less power but they also come with an added expense.I still question the added load on the power supply. Might shorten the life.
Trouble is that those aren't very easy to find either.Or plug an EHD into a self powered USB hub.
Really, I have 4 of them purchased from Amazon.Try the Amazing place.
MyDISH
my.dish.com
Limited time offer
