Does my antenna require grounding? | SatelliteGuys.US
NEC 810.15 dictates that the mast be grounded.
NEC 810.20(A) dictates that an "antenna discharge unit" (grounding block) be used on the cable.
NEC defines grounding as running wires of a specific minimum size to a "bonded ground" that attaches to your service entrance ground. This may involve multiple ground rods and connecting wires between them.
Reactions: FTA4PA and ncted
Similar to this thread, I've gotten conflicting opinions on whether I should/am required to ground the structure the antenna is connected to. Does the structure I attach the antenna to make a difference? (i.e. a mast vs attaching it to something else)
Grounding is designed to reduce the potential difference in charge between your antenna and the clouds so the lightening strikes somewhere else. It IS going to strike, just don't encourage it.
I’m not qualified to have a problem.
My training was in the Navy, and courses I took since. My last formal class was run by a Master who was retiring. Let us say, he kinda had nothing to lose and taught us more than short runs.
:D
Sent from my iPhone using SatelliteGuys App. For now.
Reactions: Wireless Engineer
