Does Slimline work on Dish Network? | SatelliteGuys.US
lgjmb
8
Hi. Silly question, but I need to know. Is the Slimline dish compatible with Dish network?
Thanks,
I have a question to add on to this. I have a slimline dish laying around. Since the slimline lnb assembly gets the standard 101 satellite from DirecTV, could the slimline dish and lnb be used to get just one Dish Network satellite such as 61.5 with its current lnb or would I need to attach a new lnb? I don't want to use it to get anything but one satellite.
i'm using a modified slimline dish and it works great. i used the yoke and lnb from a 1000.2. i cut about 3 or 3.5" off the arm to give me the same focal didtance .i'm getting 110,119,129.it's bigger than the 1000.2 ,stronger,and gives better signal
Thanks. I have done more research and I guess I'll have to use a Dish Pro Dual LNB if I want to add the new satellite location to my existing setup, which is a 1000.2 aimed at Western Arc.
uplink channels to test...
AMC HD?
