So, that means they will be able to get the HD channels on the 101 once they move them (timeline unknown, just like everything else with D*)Essentially any dome should work with the H24 since it is non-SWM capable. Although, being these domes (or most of them as alluded to in post #2) are SD and DIRECTV is shutting down those SD-only feeds on 101, you
May not be able to receive all of your channels anymore with the dome. This all depends on what DIRECTV decides to do once they remove all SD channels from 101 and start bringing in popular HD channels.
The 23 and 25 series boxes are swm required as well as the Genies.So, that means they will be able to get the HD channels on the 101 once they move them (timeline unknown, just like everything else with D*)
I must mis remember, its been awhile since I've heard the H24 mentioned ... I thought that one WAS requiring the PI
Oh, Thats right ...The 23 and 25 series boxes are swm required as well as the Genies.
Whoopsie! I was thinking about them not needing b-band convertors!H23/HR23 did NOT require SWM. The only receivers that require SWM are H25, HR34, HR44, HR54 and HS17. Also the H26 thought that's commercial only so irrelevant for consumers.
Limited time offer
