Recently a friend of mine told me about a family whose home was destroyed in a fire that resulted in total loss. They did have enough resources to build a small house on their property that is not yet completely finished. They live in a rural area that is not served by cable and they really can't afford any subscription tv services at this time.
So I donated a Coship 2300B with remote, diseqc 4x1 switch, two 75 cm dishes with lnbfs, a D* lnbf for audio channels, 300 feet RG-6 Quad, connectors, and cement for pole mounting of the dishes.
I went out to their home and planted the two 1 1/4 inch schedule 40 galvanized poles and mounted the dishes. One dish pointed at G10R and the other at SBS-6.
I strapped the circular polarity lnbf to the side of the Ku linear lnbf on the dish that is pointed at G10R for audio only. I programmed the transponder frequencies and symbol rates as well as antenna configurations on the diseqc switch.
All worked great! Plenty of FTA channels so their tv would work. Over the air reception in this area is modest at best even with a high gain tv antenna and ampifiers due to the mountains and valleys. Multi-path is a nightmare on analog tv stations. I do not know about digital signals or if they are even receivable in this area since they are UHF.
All was working great and I left, they were very happy with their satellite system.
I explained to them that it is not "cable" and is not a replacement for their subscription tv services, but it would provide them with some decent reception of Free to air signals.
I got a call today and they said that all channels show "no signal". My first thought is that the diseqc switch has failed (as they do sometimes). I talked one of the guys through the steps to turn off the reciever (unplug it) and plug the G10R lnbf straight to the receiver's lnbf input to isolate the diseqc switch as the culprit. He said this did not help. We did the same process for the other dish that is pointed at SBS-6. No signal still yet.
I could not figure this one out since i planted the dish on rigid poles. The dishes were peaked and lnbf skew fine tuned.
Well when the truth came out, one of them "tried adjusting the dishes" as one stated in order to try to receiver free porn channels from "some other satellite".
I explained that there are no "free porn channels in North america" and if there were you would have to know the downlink frequency and symbol rate before trying to point the satellite dish. The Coship 2300 does not do Blind searches. You have to know the downlink freq's and Symbol rates.
Now they act as if I am the one who "does not know what he is doing" as one stated in the background as I was on the phone trying to help them get their system back up and running. I am frustrated. I wish i had not done anything for them now and that is not the right way to feel. Some of you may have experienced the same similar circumstances.
