Double channels??? | SatelliteGuys.US
Double channels???
davethis
16
Bay Area, CA
I noticed last week when I display the guide, there are double channels being displayed. For example, it will have ch2 and then ch2 HD; ch3, ch3 HD, and so on. Is there any way not to display this? I seached in the menus but did not see anything, and also searched the site but again did not see anything that stood out.
This may be an old topic or maybe it has been there forever, but I just noticed the feature last week.
Thanks in advance!!!
If you don't want them in your guide you can do a couple of things.
You can go into the sat locals menu and hit hd priority and they will go away or you can leave them and go into the locks menu and lock out all duplicate channels. I do the locks thing since I want the mirrored hd channels in the low channel range and I lock out the duplicate channels in the 9000 range.
2nd DPP44 switch gone bad:(
Rebate form?
