DownLoads for CoolSat | SatelliteGuys.US
gpat
323
Is there any downloads for Coolsat that wont void my warranty to put in all the FTA channels and Sats and let me chose which ones I want to put in the favortites?
Surely theres got to be a better way than scanning each sat individually.
Theres already a gzillion sats(60 to be exact) programmed into my sats list.
Im guessing this is a factory default entry and can be added to as the market expands.
really no such thing and here are some reasons why
-some people can see the Atlantic satellites and some cannot. So if you load those Atlantic satellites and give it to someone in say Nevada, they can't see those
-channels change all the time...best thing to do is blind scan each satellite :)
I've done the "factory default" a couple times but I ended up scanning in all the channels again..took a while but it worked :)
Well my blind scan on G10 got 4 powervue channels and nothing else.
These are all scrambled. Im sure theres at least 30 more that could be viewed
but Im having no luck.
I realize that out of the 60 sats programmed in the Default data base that
some will be usable and some not for some locales vs others. This is why I csaid I would weed thru them by sat and only include the ones that I find attractive.
Is this something ChannelMaster can do? Has anyone taken the time and effort to compile
data that would be usable and editable?
your dish cant be aimed at G10...got some money says you're on H1 or whatever it is at 127W...there are 4 scrambled channels there...need to move it 4 degrees east :)
How Embarrassing
you were dead on that one
I dont know how that sat didnt shift with the rest when corrected for new actuator #s
Im sure they were all selected to shift with the new alignment.
It said 74 channels were found on H and 18 on V polarity is that about right?
How Embarrassing
when I've aimed dishes at G10 I usually do the same thing....end up on H1
That doesnt sound right. There are more on V than H and only about 40 free channels on G10...
That was for all channels free and scrambled
havent yet figured out how to cull the $ ones in a search yet.
I think you do this thru the auto mode not blind search correct?
Im ready to pitch the whole channel list I have so far and start fresh.
I would also like to sort them by sat so that when Im on that bird
I can surf thru them all.
Any tips?
Im from the school of hard knocks...got many a lump on my head.
Not nearly that many channels on G-10R horizontal (scrambled or otherwise)...
Almost everything on G-10R is vertical. Exceptions are VA channel(s), UWTV, and Research Channel. Those are horizontal.
Nah, I have eight... well, seven of them :eek: I knew I'd be needing them, and the price was right ($60 shipped for a box of 8)...
A few of the guys here have them, and they seem to be excellent LNBs :)
EPG on FTA
Polarizer
