DP 625 Install | SatelliteGuys.US
DP 625 Install
wdeagle1
Alabama
I have a friend who has a 625. I have a Dish 500 and a Superdish. Which dish would be the best to use and what switch would I need (or other equipment)? Which would be the path of least reistance to install?
Thanks for any help?
Charles
Does the 500 dish have a DPP (Dish Pro Plus) LNB? If yes, 1 cable needed from dish to receiver. If No then you will need two cables from Dish to receiver. Superdish will work too but you need a DPP 33 switch in order to run 1 cable from dish to receiver other wise if you have a dp34 switch for the superdish then you need to run two cables again.
Lost all timers on 510 PVR
Help, my dish 500 will only get one sattelite at a time.
