C cdyl New Member Original poster Jan 19, 2012 4 0 Jul 3, 2012 #1 When do u need to use a dp adapter?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Jul 3, 2012 #2 cdyl said: When do u need to use a dp adapter? Click to expand... When you have LEGACY receivers connected to DISH PRO ELECTRONICS. Dish Pro Plus does not require DP Adapters.
C cdyl New Member Original poster Jan 19, 2012 4 0 Jul 3, 2012 #3 Thanks. Do u happen to know anything about system info box b?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Jul 3, 2012 #4 cdyl said: Thanks. Do u happen to know anything about system info box b? Click to expand... No and you shouldn't have to worry about it unless you are just looking for trouble.
C cdyl New Member Original poster Jan 19, 2012 4 0 Jul 3, 2012 #5 No trouble just trying to get the answer for a quiz.
the mack SatelliteGuys Pro Sep 10, 2009 1,479 483 HOCKEYTOWN Jul 5, 2012 #6 boba said: No and you shouldn't have to worry about it unless you are just looking for trouble. Click to expand... LOL
Stargazer Supporting Founder Supporting Founder Sep 7, 2003 16,568 340 Western WV Jul 5, 2012 #7 Dish Network does not allow legacy receivers on accounts anymore so DP Adapters are door stops now unless you can use the power supply for something else.
3HaloODST SatelliteGuys Master Pub Member / Supporter Jul 2, 2010 6,648 97 Earth Jul 5, 2012 #8 cdyl said: Thanks. Do u happen to know anything about system info box b? Click to expand... Section "b" is some figures that have to do with lost locks on tuner 1/2. I think overall this section is pretty useless.
