DP Separator & Single Tuner Receivers | SatelliteGuys.US
Cokeswigga
266
I have seen that with a DPP 44 and a Separator, you can run 1 cable to theand then have a separator to feed the Dual tuner receiver,
but, can you use the DPP 44 and a separater to feed two different single tuner receivers
No. A DPP separater is only used for Dish Pro Plus dual tuner receivers only. It will not work with two single tuner receivers.
Anyone hear the MPEG4 Multi/Simulcast rumor?
Dish Club...
