dp301 help | SatelliteGuys.US
dp301 help
docj2005
294
st louis park mn
has anyone had this problem
my dp301-13 doesnt seem to see any sats.
i live in st louis park mn
55426
as far as i know everthing is amied right and i think the lnb is good
i think it is the box
any help ?
doc j 2005
Is this your only receiver, if not are your others working. Pull plug for 15 min, then repower and menu 6-1-1 check switch and see if you can check the switches...
Free Premium Channel HD not viewable
Using "Aux" button on remote
