J Jthomas Member Original poster Jan 21, 2016 11 0 TX Jan 21, 2016 #1 Hello All, I'm a Dish subscriber and I have a DP311 that I want to program a Dish 6.0 IR remote to work with. Is this possible?
ChadT41 THE BEST THERE HAS EVER BEEN Apr 20, 2014 11,083 4,515 Mesa, Az Jan 21, 2016 #2 It is as long as it is in IR and set for TV1. The 6.0 is an IR/UHF remote.
L LailaS@DISH SatelliteGuys Family Jul 8, 2015 83 32 Littleton Jan 21, 2016 #3 The 6.0 IR/UHF remotes are compatible with DP311 receivers.
J Jthomas Member Original poster Jan 21, 2016 11 0 TX Jan 21, 2016 #4 ChadT41 said: It is as long as it is in IR and set for TV1. The 6.0 is an IR/UHF remote. Click to expand... Thanks for mentioning TV1. My remote has a Blue #2 at the bottom. Is there a way to program it for #1? Thanks
ChadT41 THE BEST THERE HAS EVER BEEN Apr 20, 2014 11,083 4,515 Mesa, Az Jan 21, 2016 #5 Take the chip out and turn it over. There is like 15 chips so you may have the right one you may not.
J Jthomas Member Original poster Jan 21, 2016 11 0 TX Jan 21, 2016 #6 Thanks all, Flipping the key and going to the receiver manual did the trick. I'm up and running.
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,635 29,710 Rohnert Park, CA Jan 22, 2016 #7 Cool!
