I thought I had a bad DP34 switch, but now I am wondering if my 622 is fried. On the evening of the Sopranos final, I had an issue with my 622. I accidentally tuned it to one of the dish application channels TVG or HRTV (cannot remember which one) and tried to cancel/change channels while it was loading. The receiver hung and I reset it by unplugging it. Afterward, I was not able to see 110. I get the following test results.
1 2 3
61.5 119 CONN
OK OK X
DUAL FEED QUAD
So, no HD Sopranos. The next day I swapped out the Quad DP LNB and no change, so I ran 119/110 direct to the 622 and I saw 119/110 from the Quad. Called DISH and they shipped a replacement DP 34. I just installed it and I still cannot see 110. I thought I would check in here before moving home
and setting up a service call with DISH.
Thanks,
J.VO
1 2 3
61.5 119 CONN
OK OK X
DUAL FEED QUAD
Thanks,
J.VO
