dp44 QUESTION | SatelliteGuys.US
dp44 QUESTION
sprintcarcrazy
820
I want to help add a Dish to a neighbors setup, he has a 500 and a DP44, can I add a legacy 300 to the 44 to get 129 or has it got to be dish pro ?
And although the Dish 300 - 18" dish pan, should work if the LNBF has a DP (or DishPro) on it; the Dish 500 has a larger dish pan and should provide a better signal.
Depending on your location a D300 will be fine but if you can get a D500 with an I bracket that's better. And if you can get a 24'' dish, even better. You get the picture, with 129 size DOES count.
DVR VIP-622 or #625
Daylight Savings & 322 receiver
