DPP 44 switch instllation | SatelliteGuys.US
Nasdik777
3
I've installed Dpp44 (with power inserter) DN 4 receivers switch..can't make it working,,settings I think correct hook ups as well ....PROS...Please advise...!!!
Well if you are sure you have it installed right and it does not work I would say it's bad.
Now are you sure you have it hooked up right?
What does your check switch say?
2 dish 500 each lnb goes to empty port on switch Dpp44 lnb's input, powered line from CS7G goes to input one on switch for powered line and the rest of lines to separate boxes I have 2 more DN DVR and CS6G.... setting I went troug the book but I might be wrong,,, where do I find info..PLEASE advise if yu are PRO... what does it mean? " What does your check switch say?"
What the crap is a CS7G? Some FTA receiver?
Try putting one of your DVRs on the first port and make sure you have Dish Pro LNBs installed on your dish.
Two 622 questions
811 looses signal if I go to a specific channel
