Dpp Lnb?? | SatelliteGuys.US
Dpp Lnb??
sunfire01
79
DFW, TEXAS
If I have a dish 500 right now with DP lnbs can I just change those lnbs to a set of dpp lnbs and be able to feed a dual tuner receiver? If is that easy with no additional aiming of the dish?
Jason
Yes, whether you have DP LNBs (rare) or the DP Twin, you can swap out for a DPP Twin and not have to re-aim. The LNBs aren't DPP, it's the switch in the DPP Twin that lets you connect a dual tuner with a single cable run and the DPP Separator.
A re-aim won't be necessary, but due to manufacturing tolerances, and just general principles, the new LNB/Dish might need to be peaked.
Not hard if you're careful.
Transponders
2 dishes to one dish 1000
