DPP Twin Installation Information
Here is the DPP Twin Installation Information guide.
A few notes from it:
• DP Plus dual-tuner receivers require a software download to complete the installation. A special download procedure is included in the user guide.
• There is a 200' cable length limit for DISH Pro and DP Plus dual-tuner receivers with some additional limitations as detailed in the user guide.
• When connecting a Legacy receiver, a second receiver must also be connected to power the LNBF:
o If the second receiver is DISH Pro or DP Plus, the DP Plus Twin will be fully functional.
o If the second receiver is Legacy, the LNB IN port (for a second satellite dish) cannot be used.
• Legacy receivers will recognize the DP Plus Twin as an SW64 switch – this is normal.
• The DP Plus Twin may be connected to a DP Plus 44 switch, but not to DP21 switches or DP34 switches.
• A DP Plus Separator allows a DP Plus dual-tuner receiver to be fed by a single cable – it cannot be used to feed two single-tuner receivers.
• The DISH Player-DVR 921 cannot be installed using two cables directly connected to both DP Plus Twin ports at this time. The 921 software will be upgraded later to add this support.
• The DISH 721 does not have support for the DP Plus Twin at this time. The 721 software will be upgraded later to add this support.
And in particular to those who want to use this to add more satellites:
The DISH Pro Plus Twin LNBF can be connected to a DISH Pro Plus 44 switch to provide 119W and 110W satellite signals to the switch. When used this way, LNBF PORT 1 will default to the 119W position and LNBF PORT 2 will default to the 110W position. The LNBF port marked LNB IN is not used and will not provide any signal to the switch. To complete this installation, install the DP Plus Twin LNBF first using these instructions, then install the DP Plus 44 Switch using instructions which come with the switch.
Note: The DISH Pro Plus Twin LNBF is NOT compatible with the DISH Pro 34 switch in any installation.
Do not install these devices together in any system, including trunked switch installations which contain DISH Pro 34 switches.
