DPP44 and 3 reciever's | SatelliteGuys.US
WGFA
80
PA
Hi all. My question is what switch or splitter do I need to split 1 lead off my DPP44 to 2 seperate reciever's? I know that 3 off the DPP44 to 3 reciever's is best but its on the roof and kinda pain to get to. I am wondering if it is possible to just split one of the 2 already in the house or combine the 2 then make 3 or 4 out. I have 622 and 722 (2) recievers. TIA
WGFA
DPP 44 will operate only 2 dual tuner receivers with 2 swept tested cables. provided you are planning to use a seperator fo each dual tuner. Put on your climbing boots and get busy running that 3rd cable, Dude!
Thanks :up:up
Dish Installer took 1000.2
Local Channels in HD Help
