dpp44 w/ vip211 & vip612 | SatelliteGuys.US
alberto7valdez
22
great forum !!!
i just installed a dpp44 with a vip211 and a vip612. everything working but i get stuttering video on the vip211... mostly on non hd channels. everything good on the vip612... any ideas?
thanks
Any reason why you went with the DPP44 instead of a Dish 1000.2 or 1000.4? Both will support 3 dual tuner receivers and cost 1/2 of what a DPP44 does?
Have you hard booted the 211? (unplug, wait, replug)
i might be a little confused but i went with the dpp44 cause i wanted to run one line per receiver and plan on adding 2 more receivers later... using on dish 500 for 119 and 110 and another dish for 61.5... did the hard reboot and i think that fixed it... thanks
Need your help??
I have one coax coming from a dish 300 pointing at 61.5 and I have a dish 500 with 110 and 119 coaxes coming into my family room.
What switch (or switches) do I need to feed a 211 receiver and a 311 receiver? I only have one coax from 61.5 but I want both receivers to be able to get the 61.5 signal and one of either 110 or 119. :confused:
I bought a dp34 but that apparently was the wrong switch. I do not understand the lnb's / switch compatibility very well. Please help!!!
thanks
Ken.
more HD recording time?
HD Dish DVR for Std Receiver
