Drift/Pixelation Etc. | SatelliteGuys.US
bkushner
681
2
Audubon, NJ
I started having some Pixelation problems on the 61.5. When I do a system check I am getting LNB Drift -6 (used to be -5) on the 110/119 but nothing mentioned for the 61.5
Does the 61.5 show up for LNB Drift?
Brian
Brian
Yes 61.5 does....I just replaced a 61.5 LNB with a new LNB which is typically the solution....look in the details area after you get a check switch done or look in the system info screen after it gives you 100%of the system info test.
Dish Network will replace LNB Drift detected lnb's for free because they were too cheap to pay for good lnb's. It is a manufacturer's defect and Dish won a settlement against the manufacturer.
VIP 222 used as non HD Receiver
Expected VIP 722
