Driver for DVB-S 1020a on Windows 7 64 bit | SatelliteGuys.US
Hamid32
3
Lost
I have a Vision Plus 1020a DVB-S card and its driver did not install on Windows 7 x64
Anybody can help me? this is a DVB-S card, no DVB-T
I heard that, there is a patched driver for this card but i think that driver is for DVB-T card. :confused:
Is there any patched driver for this card?
My card recognized as 2 device on device manager on xp:
DTV Video Controller
DTV Audio Controller
Also i have an Intel CPU.
sorry for may bad english.
If you look back on our forums you'll see we've some long discussions about this. I was able, with the patched drivers, to get the card itself installed in 7 64-bit but it would not lock a signal. For whatever reason Twinhan has not released a working 64-bit driver. I went to 7 32-bit and using their latest drivers my 102g works fine.
I have the same card and windows 7, after I installed the drivers off the vision plus cd I had to reboot with the f8 key, and boot without driver certification. Every time I reboot I have to use f8 or it won't work. I use progdvb 64 with little to no problem. Hope that help's.
is your win 7 64bit or 32 bit?
my cd drivers cant be install on 7 and nothings happen when i execute that.
So the drivers only work in safe mode? 1020a card? That stinks!
getting 97w 101w
which LNB?
