Drop Locals issues? | SatelliteGuys.US
Drop Locals issues?
man00
SatelliteGuys Guru
128
104
Can you drop locals and then add it back if you decide to within one year or there some waiting period?
I am under the impression that Dish will never refuse to upgrade your subscription package since they will be making more money. I would be shocked if they have some sort of limit.
I don't know if they still offer 'welcome package' that I switched to. Locals are included. After getting ota channels, I called to drop the locals to save even more. I was told that was not possible.
If I were you, I'd give them a call. If you lost some locals due to the latest disagreement, Dish would be willing to go with your plan.
Reactions: charlesrshell
No limit to amount of times you add and cancel programming on DISH. There can be a $5 charge if done within the same billing period.
Your title is a bit misleading.... ;)
Need help with angles
Can't modify start/end settings for existing timers
