DSR 410 DS | SatelliteGuys.US
DSR 410 DS
ricardoalfonso
Miami
Hello does anyone knows if a DSR-410 DS (Dual Source) can be used to subscribe programming with skyvision? Thanks for your help.
If you've not had programming before then you may have to call SkyVision to see if the unit can be authorized or what the cost would be.
I think it's $35 to get a 410 from somewhere else cleared so you can subscribe. Unless you buy it from Skyvision then that is done ahead of time.
echo star model 410
Problem with sats higher than 83W
