DSR 451MN | SatelliteGuys.US
DSR 451MN
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Any one know anything about the DSR 451MN? (It has s-video)
I think this is a Star Choice box.
Will try to get the few fta at 107 i hope it works
Its an OLD Shaw (Starchoice) receiver
you should get a few freebies on AnikF1
351 Access
354 Knowledge
392 Shopping
825 Voice Print
828 CKUA
351 Access
354 Knowledge
392 Shopping
825 Voice Print
828 CKUA
I only have two universal lnb's.
Any suggestions on a low cost one that will work with SC/Shaw.
Correct if wrong need one thats range is 11.7 - 12.2 Ghz?
yeah you need a standard LNB...If you try a Universal the frequencies will be off by 150MHZ and it wont work
WineGarud Dish For Sale
Scalar F/D Setting
