DSR-905 22Khz question | SatelliteGuys.US
Inno
1,596
5
NW Ontario, Canada
In the manual tuning section of the 905 there is an option to turn on a 22Khz tone but when you change channels it is defeated and you'd have to turn it on again with every channel change.
Is there any way to turn on the 22Khz tone permanently? It would help me with my setup.
I assume the channel maps have to do that. Starchoice uses the 22k side for their 111.1 satellite and when they program the receiver to acknowledge it
Also if you check a TP that is on AnikF2 via the hidden menu (6-7-7-8-2) the TP will show as 33-64
Ah, that's probably correct. It would be handy for my current setup. I'm trying to avoid running more wires but things aren't going according to plan.
It was working just fine but I think I may have a bad cable somewhere. Going to do some swapping soon.
I want cband...
HBOHD AC-3
