DSR 905 | SatelliteGuys.US
DSR 905
stecle
380
220
Between the North and South Pole
I am going to change the battery in my DSR 905 before I put it up for sale. There are two different sizes of security screws that I need to remove to take off the cover. I ordered these two security bits (Gamebit 3.8mm 4.5mm Game bit Professional gamebit) which I thought would do the job. The 4.5mm bit removed the smaller screws but there are two bigger screws that the bits won't remove.
Does anyone have the specs on what bit I need? I don't want to keep ordering the wrong bit. I know that I can use my dremel to remove them but I would much rather do the job properly with the correct tools.
Uniden UST9900 Analog VC2 receiver power connector
long c-band feed
