dsr 922 fix for DC lock problems!!! | SatelliteGuys.US
gardo403
224
6
S.E. Wisconsin
Just wanted to take the time and share this with everyone.... If you have a dsr922 thats getting old, maybe you have one the first one's out that says G I on it verses the big M...
Well anyways I had one here that worked fine except the DC lite would blink.. then nothing at all. progressively worsening...
I tried master resets you name it.. nothing helped... Then I did some reading about a bad capacitor by the tuner...
here's a link DSR-922 Capacitor Replacement
I replaced all the 16v 10uf caps that were after each voltage regulator
in addition to the one mentioned on the site.
C159
C300
C271
C211
Also a good time to throw a new battery in too!!
Is there any HDTV Left?
New 6 foot dish with a DMX742 C/KU band LNBF
