DSR410 Asynchronous Data | SatelliteGuys.US
trinidex
892
I have a Skyvision DSR410
Port 4 on the back is labeled 'Asynchronous Data' - any idea what I can use that for?
Is that an ASI output (he asks hoping!)
TIA
TIA
Yes it would be nice however no its not an ASI output.
I do not believe you can really do anything with the 'Asynchronous Data' output.
For ASI out you need a Commercial Satellite Receiver. Like a DSR-4410
When I bought my DSR410 from Skyvision a few years ago it came with some sort of cable. I just assumed it was for the HDD200 connections. It looks like the MMAP connector on some of the other Motorola receivers. I never bothered the investigate what the cable is. I could post a pic if anyone is interested.
Is it a DB-9 to 3.5mm connector?
The DB9 port is for a HDD200
I'm thinking the other port is Baseband Output - like on the DSR92x
Baseband output wouldn't have any use on a digital receiver. It's generally only found on analog receivers for FM^2 type signals, ie FM signals modulated on the carrier of another FM signal, such as the audio on an analog TV signal.
The cable is a Y. It has a DB-9 female, 1 RCA and one 3.5mm. I have no idea why Motorola boxed it with the 410.
Interesting! If only I knew why :)
On the DSR420 the DB9 and RCA sockets are together in a "box" labelled with an "i".
satellite prices and the economy
coolsat 8000 c band dish
