DSR920 setup through switch/ loop out of receiver | SatelliteGuys.US
rrob311
941
16
New England
I have my DSR920 hooked up to the loop out of my Openbox S10. When I am watching channels on horizontal sit gets reception. However if I am tuning Vertical the DSR920 shuts the signal off on my S10. I am using a dmx242 lnb feeding it into a 4x1 diseqc switch. Is there an easy way to get past this? Why won't it work on vertical? I am currently unable to run a separate coax into this receiver. If anyone can share some setup ideas it would be great.
I had it on cband lnb and then toggled to the others but it didnt seem to make a difference. So I should set it to cband lnbf?
Should I try lnb power off on my STB? Any good lines on a dc block? I haven't ordered one yet. I turn off the lnb power on my digitrans receiver and it works but I don't think the dsr has that option.
So do dsr receivers and modern fta receivers think the base skew is 90 degrees off from each other?
OK I set it as you described and now I can get everything to come in. Which is good because I don't have to run more cable. Thanks a bunch.
DSR920 are 90 out from FTA receivers.
My DSR4530 matches my FTA equip, I don't know about other DSR units.
Glad you got it working.
Showtime has a free preview this weekend in DC2
New Solid 6' Fortec vs Used Mesh 7.5'
