DST messed up my 508 | SatelliteGuys.US
caseyatbt
62
Monument, CO
I can no longer set up a timer or record live. I have pulled the card and performed a reset.(held down the power button and pulled the card) If that is still the correct way to do it. I also, just unplugged it and let it start from scratch. I can no longer record any way, any how.
Everything worked fine yesterday.
i had to delete all the timers i had set up and start over from scratch. the way i do a hard reboot is to turn receiver off then unplug it pull card out and then reinstall card then plug unit back in after about 2 minutes.then wait 2 or 3 minutes to turn unit back on.
Guide is always stretched
What happened to my recording?
