DTV Pointing Meter Settings | SatelliteGuys.US
pointsouth
Austin, TX
Is anyone out there using the Fast STrike Satellite meter to point to 101W for DirecTV dishes? I am trying to pin down the values needed to make the meter work right. I have gotten some of it from Lyngsat, but still need to know the LO (Local Oscillator Frequency) and whether to chose 13V or 18V and wherther to haqve the 22KHz set to on/off?
Thanks for any help you can give me.
I don't have a definite confirmation, but I believe the local oscillator is at 11750 MHz (it will be close to that in any case). 13 V will give the odd transponders, while 18 V will give the even channels. The 22 kHz signal is only for the 103, 110 and 119 satellites.
Adding a multiswitch question
What day in May for new HD?
