dual feedhorn help | SatelliteGuys.US
dual feedhorn help
fj45lvr
12
anyone know if there is a difference between the Chapparal II+ and the Chapparral II+ wideband? what is it?
I want to recieve digital through my BUD and slave a pansat 2500 to it. What is the preferred feedhorn of the two??
I will also have to buy a ku lnb and Norsat was recommended?
The regular corotor is c/ku linear, the wideband is circular C-band and linear c/ku, so unless you want a few channels off of NSS-806 then the wideband is not needed, I would get the regular corotor with some Norsat lnb's.
