dual output c-band lnb to multiple receivers? | SatelliteGuys.US
absentfriend
15
victoria, bc
I do a search, it look like to share a C-band reception to multiple receiver, you should have a 2 output lnb, then a sw43...
I have BSC621-2 (C and Universal KU-band) LNB, any recommendation for a dual output LNB to replace it?
you would need a dual output LNB and a 3x4, 2x4, 3x8 etc multiswitch
check satelliteav for the dual. They might still have some avaialble
C-Band Mounts - Looking for Options
Yeah, I know... It's an Atlantic Bird but...
