Dual Tivo's Same Remote Conflicts? | SatelliteGuys.US
ScottJayhawk
32
A while back I got two of the 250GB Samsung Tivos for my DTV, thought I'd put them both on the same TV - until everything I did with one remote was happening to the other one.....not good. So I put one of the Samsungs upstairs and paired the other Samsung with the Sony.
Now a few years later on the main TV I have the Samsung with one remote and a DTV R15 with a different remote - no problem.
But, as times change and everything becomes DTV only, what happens with crazies like us who have multiple DTV boxes side-by-side??
For example as I look to upgrade to HD upstairs, one R15 and an HR10-250 or hopefully an HR20-250 soon enough - will they both work or will the remotes conflict??
Or in a perfect world - two HR20-250's side-by-side, can it be done?
Any thoughts, insights, advice, riducle is welcome....THANKS!
You can even set your dual TiVo remote addresses on your Harmony! We have the HD TiVo and standard R10 side-by-side. Either the Harmony or the separate remotes from the two TiVos control fine without conflict.
Set the addresses and be happy.
SD Pic Quality from HR10-250?
Setup issues getting Local Channels with Birdog
