DVB Dream Transponder lists | SatelliteGuys.US
Magic Static
7,498
4,853
Montana
I'm trying to find where DD installs the transponder lists in Win 7. They are not the ones in the DD program folder. Changing those does nothing. They are in an APP DATA folder or something of the sort. I once could find them but been searching for over an hour and cannot find them. Can somebody point me to the directory please?
Ok I found out what's goofing me up. DD doesn't do C/KU even though it will let you set it up that way.
Mine was installed in windoze 8.1 has "D:/satellite/dvbdream/transponders", changing these files does affect scans. Think there was an option when installing to separate the user data under ./usr/[name]/appdata/dvbdream/..., usually on the C: drive. I preferred to keep it all on one drive/directory.
REVIEW - AI Turbo S2 Meter - The BEST Gets BETTER!
Kuwait lineup change
