anyone try these out ? how do you like them ? they have the same 30Ms/s limitation the technotrend s2 usb one does ? will it work with tsreader ?
whats the pilot options supposed to do ?
I finally got a lock on the dvb-s2 mux on G-26, the software logs 12 channels in the channel list as tv1-12, but when I double click on one nothing happens, no picture, audio, nothing, something is still not right but I think I am close.
aparently the technotrend s2-3600 (usb) has issues locking anything with a symbol rate higher then 30000. the s2-3200 (pci) does not have this issue.
You guys do know that these channels are H.264 video right? That means you'll need a codec installed on your computer that can handle it. If you have software to playback blu-ray or Hd-dvd installed you probably have a codec installed that can handle H.264.
Limited time offer
