DVBDream 1.3 Released | SatelliteGuys.US
digiblur
14,190
4
Louisiana
It just keeps getting better and better!!!
http://www.dvbdream.org/
* BDA support (Limited DISEQC support* because of BDA restrictions!)
* Timeshift (ram + disk cache)
* Network Scan (No need to update INI files anymore! New tp lists are gathered from the stream)
* New quick favourites system (works on chlist general tab, faster access to favourites)
* MDAPI plugin interface is now more compatible. (now it can detect Provider IDs, no need to use "Auto PMT" option on plugins and OnExit() bug fixed)
* LAN streaming added (Options->Preferences->LAN Streaming)
* Changes in record manager to prevent excessive cpu usage on slow disks (No high CPU usage during MPG record anymore !)
* Aspect Ratio options improved (supports embedded AR modes)
* Cropping (Vertical/Horizontal zoom) added
* "Return to default options" menu item added (in main menu->File)
* TS-record improved. Now possible to record ECM, EMM, Teletext and all audio pids.
* Now DD can load the plugins from \plugins root folder and possible to use subfolders inside \pipxx (e.g. \plugins\pip00\mdttx\mdteletext.dll)
* Some interface customizations for DVB-T and C
* Performs better during channel changes using keyboard and RC.
* Snapshots are now saved in JPG format instead of BMP.
* Sleep timer added (Main menu->File->Sleep Timer)
* Displays chroma format in status bar (4:2:0/4:2:2/4:4:0)
* New option to report channel frequencies in short format (just press CTRL + ALT + C keys on any channel) e.g. "13.0°E 11766,V,27500 RAI1 (RAI) 4:2:0"
* Module: Momette's DVBEPG module update for latest DD included !
* Module: X05's New module, CHLTools, capable to assign SID numbers as Ch.Numbers in remote list and capable to auto assign EPG/LCN channel numbers to remote list (this might be quite handy if you are following the schedules published by provider!) and CHL optimization features.
* Module: Signal Display included (to adjust your dish, signal levels are indicated by voice!)
* Module: Level log included (stores signal levels in a file with periodic samples)
Are they going to bring back the support of Nexus-S on their new versions? I would like to try their new "LAN streaming added (Options->Preferences->LAN Streaming)", but I have a nexus-s v1.3.
I got to format my machine tommorow and try this. :)
I cant get my Twinhan card running on Vista. Vista sees the card as a DVB-TV 878. However I can't get it to work with tsreader or dvbdream
Scott,
My XP machine tries to do the same. I had to remove the DVB-TV878 driver from from my machine so it only loaded the drivers from the Twinhan CD. I also can only run stable on 1.2c, but I may have to try out this new version
I have the Twinhan 102g and Genpix device on my HTPC. I just pick the device and away she goes. The features this guy is adding is nuts...excellent developer! I could easily say hands down, by far, this is the best DVB PC program out there. And guess what? It's free!
1.0 Meter Primestar
Deleting channels on Pansat 3500S
